quick rift stating question (steam)
23 Mar 2011
just brought and downloaded this from steam
i already have an account as i tried the beta, so do i just use that account, put cd-key in and access my first month of play?
thanks
think you will need to enter the key on your trion account management webpage. - https://account.riftgame.com
Not sure where the key is shown in steam because I bought a boxed copy.
Then you should be able to just launch the game and sign in with that account.
If that fails that a quick email/call to trion support will set you on your way.
just bought and downloaded this from steam
thanks
depending what server you go on/which side you pick feel free to add me (SilverTongue) I'm a Guardian on Blightwield
