7 Jun 2007 at 11:38 #1 EddScott EddScott Soldato Joined 18 Oct 2002 Posts 9,455 Location Pembrokeshire Just got a 2nd hand 950i but it has arrived with no USB cable. My GF has an 810i so was wondering if I can use that USB cable for the 950. Thanks
7 Jun 2007 at 14:37 #2 McDaniel McDaniel Soldato Joined 15 Aug 2003 Posts 19,917 Location Essex My k800i USB cable works with my w810 and my sisters k810i as long as it fits then yes, im pretty sure most newer SE's use the same connections
7 Jun 2007 at 16:29 #3 GeForce GeForce Soldato Joined 14 Feb 2006 Posts 4,644 Location Surrey, UK Yup the cable will work fine. The DCU-60 and DCU-65 are compatible with all Fastport devices. Jon
