Hi,
Just a quick question regarding the use of seam sealer. One of my rear doors has started to rust on my Focus and Ive found out its due to the seam sealer between the 2 door skins is loose.
The seam has fully come away from the door now so Ive removed all the rust and sprayed it with rust killing primer for now. Ive ordered a tube of PU seam sealer from ebay and not sure exactly how to apply it. Do i apply it to the bare metal or prime it then apply to the primer? I'm hoping its the latter as Ive sprayed 3 coats on today and don't fancy removing it .
