Quick settings question
ajf
ajf
30 Oct 2006
Worcestershire, UK
For some reason having moved my PC today it lost all its BIOS settings.
Of course hadn't written the OC settings down anywhere!
Managed to work out most but cannot remember if I need to change these:
PCIE Frequency - default 100
FSB Strap - default Auto
Thanks
Andrew
Oops sorry. Forgot about this thread!
After searching my memory and scraps of paper rest of overclock has been set as:
CPU multiplier 8.5
FSB 420Mhz
DRAM 1053Mhz
DRAM Timing Auto - no idea what to set to manually!
CPU voltage 1.35
CPU GTL Voltage Auto
CPU PLL voltage 1.54
FSB Termination voltage 1.12
DRAM voltage 2.00
North Bridge voltage 1.14
South Bridge voltage 1.20
PCIE voltage auto
CPU is an E8400
m/board Asus P5Q Pro
Memory is 1066Mhz
Idle temp 44
Based on the above do I need to change/set the orginal settings I asked about?
