Quick SLI question
7 Sep 2007
Edinburgh
I have the EVGA Superclocked 8800GT. If I buy another but lower clocked, will both cards automatically configure to the same clock speeds or will I have to do it manually?
Thanks.
They will both run at the lower speed, so you'll have to bump up the speed of the new card you buy, and hope it'll reach as fast as your superclocked card (which it should really)
I'm not too sure how to do that. So will they both run at the lower speed without me having to change any settings?
Thanks.
Yeah. SLI defaults to the lowest common denominator. Of course, as said, any GT card ought to run the same speed as your EVGA so set them both up with rivatuner to run at the EVGA speed.
If you don't want Rivatuner loading up every time, once you are happy that the nex card is stable at the EVGA speed, just flash the bios of the card to match the EVGA speed.
