Just using nlite to slipstream sp3 to my copy of xp. On the actual app it says you should only add the latest service pack to the copy, and it gives an example stating there is no need to add sp1 as sp2 supersedes it.
The question: Will this be the same for sp3, or do I need to add sp2 and then sp3?
Thanks in advance
Thanks in advance
