We're going to do my usual beef shin and Guinness stew today, but realise we need to get out and about, and not going to get back in time to do it on the hob (my usual method, in a casserole pan). So we're going to give it a go in the slow cooker. Time suggested seems to be 8hrs on low, but I'm getting confused about how much liquid to use. Most top tips suggest as little as possible due to it not evaporating, but then other tips suggest you need to cover the meat?
We're aiming for a thick gravy so I'll definitely brown everything off first, deglaze the frying pan with the Guinness and then put it all in the slow cooker. But if the meat (1.4kg of shin) isn't covered, should I top up with stock or not bother?
Thanks!
Thanks!
