Hello all
Just wanted to check this spec is all ok, Will be using the machine for photo editing mostly, occasional light video editing and occasional gaming.
I've chosen a motherboard with on board graphics as I Will be adding the graphics card at a later date.
I might also change the RAM to this if it comes back in stock befor I buy? Do you think it would be worth it over the G.skill?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-083-GL&groupid=701&catid=8&subcat=1387
I'm open to suggestions if I could get better parts but want to keep the budget the same.
cheers.
cheers.
