Quick Spec Check Before I Order Please
18 Oct 2002
Scotland
MB-062-GI Gigabyte GA_965P_DS4 (Socket 775) PCI-Express DDR2 Motherboard (MB-062-GI)
£109.95 £109.95
GX-047-CO Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
£199.95 £199.95
MY-014-GS G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5 Dual Channel Kit (F2-6400PHU2-2GBNR) (MY-014-GS)
£114.95 £114.95
HD-070-WD Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache - OEM (HD-070-WD)
£63.95 £63.95
HS-017-AR Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR)
£14.95 £14.95
CA-025-EN Enermax Liberty 500W ELT500AWT ATX2.2 Modular SLI Compliant PSU (CA-025-EN)
£59.95 £59.95
Subtotal £563.70
VAT £98.65
Total £662.35
Will be reusing my:-
Lian Li PC-65
LiteOn DVD-Rom
Pioneer 111 DVDRW
Floppy, etc
Anyone think of anything else i need (apart from CPU coming from elsewhere)?? No PSU to mobo leads, that kind of thing??
Cheers,
Nice try m8 ;) You never read all the way through did you :D
DOH lol sorry bout that. Well that should all work together, suppose the only thing you might want to check is if that Motherboard will take the Arctic Freezer with no hassles.
Also do you have some AS5 for the Arctic Freezer?
The Enermax will come with all the PSU leads you will need.
Hopefully the Arctic Cooler will fit and i've got AS5 here as well.
Going to order just now, cheers
