Quick speck check please? :)
5 Dec 2006
Aberdeen
Hey all, I have posted a few times before with builds I have had in mind but now I actually have the money ready and first thing tomorow morning I am going to order it. I have a good build in mind and I am just hopeing if anyone has any better ideas I can see them by the morning.
This is what I have so far:
(budget £900-1000 and main use is going to be heavy gaming)
drop the 250GB hdd and get the 320 for £4 more i say.
drop the sata cables unless you want them, even then i would order them at a later date, since the MB should come with some that are 45cm long. you will be better off seeing if 45cm is long enough for you to route your cables so that you case is tidy or not before buying extra cables.
Have changed the 250gb to a 320gb and the extra cable is because I believe the mobo only comes with 2 cables? and i will need 3, 2 for hdd's and one for the dvd drive.
If you're getting Vista i wouldnt get that optical drive, i just got my system and that drive wasnt compatible. Also couldnt load the drivers as i didnt have a floppy drive.
