Quick Survey for Cloud Users
I like clouds so done.
It's not a very encompassing survey.
Do you trust your provider;
-yes
-Never really thought about it
Wheres the no?
Edit: why do you need to know?
I can understand it isn't the best survey as I wanted it to be brief and straight forward.
That's fair enough but such a thing is rarely straight forward. Guess it depends what you're using the data for but the question I queried is kinda one sided.
Edit: Erm ok you've deleted your post :confused:.
7. Either 1st or third option is redundant.
Done though for a few questions where there is a third option e.g. "if not why not" you should have made it just two options i.e. either "Yes" or "No (please explain why?)"
OP, nothing on the form was clickable, even though I had all scripts enabled.
But to answer your questions on here:
Qu1. Yes
Qu2. Google Drive and Dropbox
Qu3. Sharing photos with family (with shared folder in Explorer)
Qu4. 1-5 years
Qu5. Never really thought about it
Qu6. Doesn't really bother me
Qu7. Not concerned
Qu8. Cloud is nothing new. That was X Drive in 1999.
