27 May 2012 at 08:43 #1 OverDrive OverDrive Associate Joined 28 Feb 2012 Posts 1,050 Location Herts Should I use the compond that came with my Phanteks PH-TC14PE or my MX-4? Which is better? Thank you.
27 May 2012 at 08:48 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent I would probably use the MX4
27 May 2012 at 09:35 #3 olivier renault olivier renault Soldato Joined 1 Apr 2009 Posts 9,950 Phantek compound should be good. The NH-D14 and the SilverArrow use compounds arguably better than the mx-4.
27 May 2012 at 17:18 #4 j.col j.col Soldato Joined 31 May 2010 Posts 4,563 Location Bedfordshire not much difference between any of them imo, go with whatever
