Quick tyre / puncture question
28 Jan 2005
Southport
Hi all,
Spotted this morning when I pulled into work, ive got a small nail in my tyre. Well it looks more like a wood tack. The head is no more than 2mm diameter.
Got a tyre pressure thingy in my boot so i tested it and its not loosing any pressure.
Do you think I should take it and get it repaired?
Thanks
You might be lucky then and be able to have it repaired. If it's an old tyre however, it's probably not worth it, just get a new set
They are Goodyear F1s :o im cursed with tyres ive had 3 new tyres and 3 punctures within 8 months of having these.
Even tho its not loosing pressure I should still get it repaired?
