Caporegime
- 8 Jan 2004
- Rutland
Sorry for another tyre thread, looking at 2 new front tyres for my 2.0T A3. Looking around I guess my top choices are:
Tyre size 225/45/R17
Falken FK-452 @ £186.52 fitted
Continental Sport Contact 3 @ £236.04 fitted
Those prices are from blackcircles.
Is reinforced the way to go? I understand it means stiffer sidewalls so sharper handling at the expense of harsher ride?
I spend most of my time plodding up and down the M1, so ideally want something that will wear well, are the CS3s worth the extra or is there anything else I should consider?
Thank you
Thank you
