Quick UT3 bot question
14 Mar 2004
Brit in the USA
Is there a way (as in previous versions) where you can see what the bots status is when you're viewing the scoreboard? For example, attacking, defending, holding - or even their location? As it is, I issue the bots orders, but then it's hard to keep track of what they're doing or where they are - it gives me no information. Or am I missing something?
I don't even know how to find the scroe board midgame :(
F1
Might be (almost certainly is) possible to write a mutator to do it. I think there are some functions in the unrealscript bot class that tell you which state it's in... would just be a case of creating a new scoreboard. Or could probably add something to the HUD... Mutators probably can't be used in campaign though (?)
May give it a go myself if there isn't another way. I have written a mutator to make bots drop the flag / orb when you press a key - but of course they just go and pick it up again straight away
