Quick VB 6 Question
4 Sep 2005
London
Is it possible to creat a drop down menu using custom images?
For example clicking on the menu and a list of country flags appear for you to select from.
Any ideas? :)
Thanks
You will need to use the ImageCombo which is in Microsoft Windows Common Controls 6.0 - might also be in 5.0, have not check though.
TrUz
