Quick Virgin Media question.
5 Feb 2004
South Shields, UK
Does anyone know if they block incoming port 25 SMTP connections to their client IP's?
Trying to setup an Exchange at home for learning purposes and don't even seem to beable to telnet into my external IP on port 25. Port 80 is fine though.
Any help would be great :)
you should be fine - you've set it up on port forwarding on your router? - if you try port 80 from the outside you may get the cablemodem page, or the router on the end if you've not done it...
Kev
