Quick Vista Question
19 Jan 2005
Hey if I go up to Vista, doin a straight upgrade, i.e. not booting off the disc, will I still be able to use my wireless card? Also, if I dont like Vista, can I still downgrade back to XP, using the same method?
Cheers.
That would depend on your make/model of wireless card, and if the manufature has released vista drivers yet. You'd be best off checking out their website.
As for downgrading it, i've only installed in on a seperate partition so not sure if you can roll it back.
no you can't downgrade.
I'd advise installing it on a different hard drive.
And the broadcom G chipsets are supported....that's all I know.
