If I don't change the voltage and keep an eye on my temperatures.
Am I right in thinking that I can't possibly damage a CPU?
Is it considered safe to overclock as far as you can without changing voltages and whilst keeping an eye on your temps?
As you can tell I'm a complete noob.
Going to do some reading up, but was just wondering if this was a safe way to start an overclock before getting the confidence to then change voltages for pushing further.
Jeez, hope I'm making some sense here.
Just I am going to order an i7 930 and want to know before hand the risk of an easy overclock (I'd like to get it at 4ghz, but only hwen I get the confidence - Will 1st just want a completely safe easy overclock with no risk).
P.S. Also getting my post count up for free P&P
Stay withing max recommended volts and temps and you'll be fine. Just remember to do it in small increments, testing stability with prime95/orthos/intel burn test/LinX as you go to see what your load temps are and to make sure it runs under load! See how far she'll go
