Quick Vostro Bluetooth question.
8 Jun 2005
On Dells site you ahve the option for a £15 bluetooth upgrade.
Does this mean you are upgrading the quality/speed of the existing bluetooth module?
OR
Does this mean the Vostro has NO bluetooth AT ALL unless you pay an extra £15?
Cheers,
G
could I slam a working bt module from a dead hp into the vostro?
Unless it makes use of dells bluetooth internal data cable then it won't work.
There are a few spares shops that sell dell bluetooth modules or you can get it from their own shop, so it is easy to get hold of one if the hp module doesn't work.
It's best to order the bluetooth module from dell when ordering as it saves the lengthy process above of tracking one down.
