Quick Wireless Connection.
21 Apr 2007
No, you don't need to buy a seperate router and ADSL modem. Just buy a router with an ADSL modem in it.
You'll find them HERE.
Do you have a particular preference for D-Link? And do you really need 802.11n?
Yeh i want newest stuff price wasnt really issue aslong as i wasnt talking 500smackers.
I only want the D-link one because ive read how fast and reliable it is but unfortunately u cant get one with a built in modem.
If you are hooked on the idea of a D Link then just get the model number of one that matches your needs from their web site and type it into Google. Some retailers who have it are bound to come up near the top.
On a separate note, why D Link? I have always found their parts to be middle of the road performance and build quality. I would personally look at one from the likes of Draytek if I wasn't too worried about spending a little more for the best.
Ok well what other routers should i look into? im not hooked on idea of d-link i just thought the modem i listed above was one of best performance wise so reviews said anyway.
