I’ve noticed on the Gigabyte x570 board it has a 8 pin power and next to it a 4 pin power supply for, what I believe, the CPU power.
The manual doesn’t really explain if both are required whether I use one or the other. I have a 1000w PSU and the cables to put in both so should I? Will it hurt? Should I only be using one of them?
Thanks,
M.
Thanks,
M.
