Quick XBox question...
18 Oct 2002
Bristol
How does the analogue component RGB; compare with VGA, compare with HDMI, when used with a 1366x768 HD Ready TV?
Depends on the TV and in most cases the difference is minimal. However, for watching DVDs the xbox will only upscale through VGA and HDMI I believe, therefore most people, including myself, prefer them them. Personally I get more tearing through VGA in some games so use HDMI.
Favourably - I notice a teensy bit of ghosting on the dashboard text but in games, the display between component and HDMI looks exactly the same.
Thanks, I don't have a VGA or HDMI cable handy. Just wanted to check that I wouldn't be losing out significantly by using RGB component.
