Ok quick question. I made a schema file http://70.190.220.164:82/mapXML.xsd - i need this check an xml file and force everything to be in order and disallow any unrecognised tags.
At the moment i have something like this
how do i force it? I don't want to do it explicitly with prefixes - but i want the checking to be tight.
thanks
sp!ke
Code:
<?xml version="1.0" encoding="UTF-8"?>
<schema xmlns="http://70.190.220.164:82/mapXML.xsd"
elementFormDefault="qualified"
attributeFormDefault="qualified">
<connectionList>
<connection connectionURL="">
<databaseList>
<database databaseName="" priref="">
<brieffields>
<field type=""/>
</brieffields>
<detailfields>
<field type=""/>
</detailfields>
</database>
</databaseList>
</connection>
</connectionList>
</schema>
thanks
sp!ke
