quick XPS question
29 Jul 2008
Hi all,
going to buy a XPS dell and quick question ,
I not really concerned about 4k screen tbh but the 16 gb memory very attractive, question is, couldn't i just upgrade the 8GB one easy enough and save the money?
XPS 15 - 9550
Processor: Intel® Core™ i7-6700HQ (6M Cache, up to 3.5 GHz, 4C)
Windows 10 Pro (64bit)
8 GB (2x4GB) 2133MHz DDR4 Memory Non ECC
256GB PCIe Solid State Drive
No Optical Device
2 GB GDDR5 Nvidia® GeForce® GTX 960M
Software
Dell Wireless-1830 802.11ac, 3x3,2.4/5GHz + Bluetooth 4.1
Primary 3-cell 56W/HR Battery
15.6 Inch FHD (1920 x 1080) InfinityEdge Non Touch Display
Internal Qwerty Backlit Keyboard
or a
XPS 15 - 9550
16GB (2x8GB) 2133MHz DDR4 Non-ECC
512GB PCIe Solid State Drive
No Optical Device
Software
Primary 6-cell 84W/HR Battery
15.6inch 4K Ultra HD (3840 x 2160) InfinityEdge Touch Display
Well if happy with the smaller 54whr battery in the 8gb model them go for it and just upgrade it yourself yeah - otherwise you'd need to go for am SSD only model to get the bigger 84whr battery ...
The underside is pretty easily serviced so you shouldn't have a problem opening it up and sticking in 16gigs of ram or even 32gig if you fancied in future!!
