Quickie Excel help?
28 Sep 2008
Britain
I have a column (D) of numbers. In column E, I would like a Y for Yes or N for No to appear in the number in column D is greater than or less than the number 5
So, if Cell D3 has a 3, Cell E3 shows a Y (less than 5)
If Cell D3 has a 8, Cell E3 shows a N (more then 5)
I'm sure it would be along the lines of:
IF(D3 > 5.....(something something) :p
Ok, another quickie hopefully.
I have a cell which is NETWORKDAYS. It looks at the date in coloum b and c and works out the differences in days. However, if a weekend is within this period, I want NETWORKDAYS to subtract 2
So, I have a coloumn called Weekend which is a Y or N answer. I guess this is:
If cell =Y then -2
how do I formt that
=IF(E3="Y",SUM(D3-2),D3)
replace E3 with the cell for the weekend cell.
Ok, thanks Morba, how do I add the if statement to the formula thats already in there?
At present, I'm trying:
=NETWORKDAYS(B7,C7), if(G7="Y",SUM(D7-2))
Where, B7 is start date, C7 is end date, D7 is the cell this is all going in and G7 is the Yes / No
