I have tried to google for this but there seems to be very little information about it.
Basically I have been given a quicksilver G4 which only has a cdrw drive and I would like to chuck a dvd-rw drive in there for good measure.
I cannot for the life of me find a guide on how to do this, I mean I should be able to figure it out but I wanted to check to see if anyone had some solid advice to give.
From what I can figure out you have to pop the front off, and to do that you need to take the to frotn handles off by undoing the 4 allen bolts which then gives you access to the front, from which you can un-do the screws on the cd drive and slid it out.
Is that the right way to do it?
