Quicky yes no question
16 Feb 2006
I want to test an ati card in my pc which i use an nvidia card in. Will it boot up fine and show it work without causing problems to the system
well i screwed it up last time so i'd rather just pop it in, make sure it's giving an output then pop it out if its possible
I'd put it in, but dont let it go into windows. If it works, you'll be able to get into the BIOS. If you boot into windows with it it might confuse your drivers.
