Quiet 120mm case fans with LED - are there any ?
19 Dec 2002
I'm a fan of the Akasa amber fans but they don't have LED
The Akasa fans with LEDs are noisy, as are the Thermaltake Thunderblades...
Anyome know of any quiet 120mm fans with LEDs ? I can't seem to find any on OCUK
SilenX do these in a range of colours...don't know if they are any good tho
Features:
Fan Swept Forward Fan Blade Design
Smoother, Thinner Fan Blades
Highly Efficient Hypro Bearings
Vibration Isolation Mounts
Built-in tachometer for motherboard RPM monitoring
Built-in LEDs
Specifications:
Fan Dimensions: 120 x 120 x 25mm
Fan Input: 12V/1.2W
Fan Speed: 1500 RPM
Air Flow: 64 CFM
Noise Level: 14 dBA
LED Color: Blue
Three Pin Connector (Supports RPM Monitoring)
Four Pin Connector
Hi there,
I'm using 3 SilenX blue LED fans with my case:
2 x 80mm fans as intakes at front and 1 x 120mm exhaust at the back
They're connected to a fan controller with the 80mm fans turned to 50% (at full speed they emit a mild whooshing sound) and the 120mm running at full speed (pretty quiet).
The 14bB figure quoted by SilenX could be an exaggeration though.
Motherboard temperature according to Asus PC Probe II is currently 38 degs although the heating in the room is turned on and I have a Zalman VF900 cooler fitted to my graphics card.
Thanks guys. Another idea has just come out of this actually - I could always just buy a fan controller and use with the existing fan to regulate it's speed as necessary :)
Another vote for the Aerocool turbine, just need another one to fit to my Scythe Ninja and evry fan in my system will be an Aerocool. Very quiet.
bbreezeuk said:
coolermaster LED ones spin at 1200rpm and are silent highly recommend them
i 2nd that if u lisen hard in a quiet room u can here them just at 12v at 7v no chnace of hearing them , cheap too about 5/6 quid each compaired to 12to 20 for as quiet fans
KillBoY_UK said:
i 2nd that if u[Sic] lisen[Sic] hard in a quiet room u[Sic] can here[Sic] them just at 12v at 7v no chnace[Sic] of hearing them , cheap too about 5/6 quid each compaired[Sic] to 12to 20 for as quiet fans
The aerocools are quieter ;)
There was a roundup of 17 120mm fans, the aerocools were only barely louder than Nexus fans which are regarded by most as the best quiet fans (Silent PC Review for example) and pushed about the same amount of air.
P.S sorry for all the "[Sic]"s, just that it is easier to read if you take your time writing the post.
