Quiet 120mm Cooler?
26 Aug 2004
Manchester
Quiet 120mm CPU Cooler?
Want to get rid of my TT for something quieter and a bit easier to fit.
Would it be worth spending an extra ~£10 for a Thermalright Ultra-120 Extreme over the standard Thermalright Ultra-120?
Are the Noctuas quiet?
Anything else I should be looking at?
What should I go for?
Edit: Sorry, should specify CPU cooler.
I have 3 Noctuas P12 in my case and they are pretty quiet. Noctuas S12 are silent, but they do not move as much air is P12. At the end of the day you can set a lower speed of P12 to get them totaly silent.
Yeah Noctua's are good, I have 2x 120mm and 2x 80mm they are silent. I hear my hard disks more than anything ><
Maybe you could just change the fan of your TT rather than buying a Thermalright 120/Extreme or perhaps buy the Noctua cpu cooler itself as it comes with a fan, the Thermalright doesnt.
Just change the fan of your TT it is the cheapest option
Seconded. The TT is an awesome cooler, but the stock fan isn't that great.
And swapping the entire cooler for a different one that's "easier to fit" seems a bit of an odd idea to me!:)
