quiet 120mm uv fans plz
You after UV specifically, not LED ones?
I know of some good ish LED ones, I will see if they do a UV version. :)
(what colour?)
CoolerMaster LED fans have been good to me. Got two blue 120mm ones in P160, very quiet and they've got a transparent look to them, which is quite cool. They use 3-pin motherboard headers (but come with a molex adapter), so you can control their speeds from your BIOS/motherboard software, which is very useful.
Yeh, the CM's or some AC Ryans would probably be your best bet.
The Akasa ones are ok, but take the above two in preference. :)
think ill opt for the ac ryan's, and i see they also produce a 92mm veson so i can replace the side window fan as well thanks for the help guys
