- 28 Feb 2012
- London
Can anyone suggest a very quiet 200mm fan to replace the stock Corsair fan in my 650D?
Thanks
Thanks
I've just put in the BitFenix Spectre PRO 200mm Fan - all black in my 650D and it's made huge difference I also replaced the top fan with two corsair AF140s. One thing you should do is cut out the mesh in front of the 200mm front fan.
I have heard that cutting out the mesh is supposed to make a big difference. Thanks.
Agree with this. Good value for money as well.I had a HAF X case with the coolermaster megaflow 200mm fan, that was silent, moved a metric **** Ton of air and worked well on a fan controller.
I have a bunch of bitfenix spectre pro fans, 120mm and 140mm and I wouldnt buy them again.
they make scratchy noises every now and again, dont push a lot of air and are noisey for the amount they move.
Ive also just bought a couple of 200mm Bitfenix Spectre Pro.
They make a nasty scratching noise. This can be sorted by stripping the fan cleaning out the grease and replace it with thick oil.
The thing is Mick as you know, people shouldn't be receiving them like that. I returned 2 of them to overclockers because of the grating/scratching sound, they were very good about it and understood that it can be an anoyance.
Ive been more than happy with the 200mm megaflows.
