Quiet afternoon at work
neilw said:
Its a quiet afternoon at work, and I've just found 6 floppy disks containing Windows 3.1
Should I install it? :D
erm .... why not? :D
If you do post images, You probably won't be able to install it on a normal system unless you have some mmx systems lying somewhere ;)
You could use vmware or Virtual machine ^_^
I've installed Windows 95 on a P4 3.0 before and its a nightmare, you have to hack loads of stuff to get it to work.
I guess 3.1 would be hopeless.
And where you getting drivers from?
Ace Modder said:
Is NOT an operating system! It's a GUI :)
so what sits behind it? code.... thought so. there for its operated. and there for its a system.
os 3.1 :)
EDIT: you don't say you have GUI 3.1 do you? when people say what OS is that, its 3.1...
People don't say what GUI is it? ....... ;)
