- 21 Oct 2004
- Wales
My current cooler is dumping all the heat inside my case so I have decided to improve the cooling situation for my CPU. Now I know one of the benefits of an ALC is that the heat will get dumped outside of the case so I have decided to go that route however I need some suggestions on what to get.
My cooling needs are mostly just for gaming but I need to have the cooler be as quiet as possible as I have hypersensitive hearing. So any suggestions on which ALC and fan setup I should look to get, I will be running at stock. My specs are:
Which ALC and Fan recommendations would be fantastic...
4790K Stock No OC
Asus Strix 1080
Z97-AR Motherboard
16GB 2400mhz DDR3
Fractal R4
