Quiet and Cool.
14 Sep 2009
Northumberland
Okay, I currently have the NZXT Panzerbox case which, yes, is nice and cool, but bloody hell is it loud.
It also has no dust protection which I don't like as my PC investment is a lot of money for me & to have it bogged down by dust with constant cleaning is a chore.
So, as size doesn't really matter, could you help me decide. I'm looking to spend a max of £130.
It needs good cooling + a decent quietness and has to be sturdy with room for atleast a 5870 as I like case room. These are my ideas, and could you help me choose :)
CM Storm Sniper, favourite of these :)
Lancool Dragon Lord + Window in Red.
Thermaltake Element G.
I hear the 1st and last are very good at cooling, and the middle one is meant to look great.
Thanks in advance for any input :)
well i have just got a fractal r2 to replace my antec 1200 and its doing a great job cooling my rig at teh same time being very quiet. The only down side is you have too buy extra fans if you want it cool, i bought 3 140mm plus i had a few 120mm
silverstone fortress ft01 £126 but it's silver, black one will cost you £135 cant really get more sturdy the thing is thick thick aluminium very heavy weighs a tonne.
My only issue is the top fan filter being hard to remove but not really an issue if you clean top with a strong hoover or have it as an exhaust instead of intake.
And the gap between the back and the side panel could do with being a bit wider but everyone seems to manage with cable management still.
I had problems with mine as I took it apart and forgot to remember exactly which screw goes where.
Loving the case now though.
http://forums.overclockers.co.uk/showthread.php?t=17992382&highlight=silverstone+fortress+ft01
C64, i really like that case :D
Do's it come with the Noise dampening, or do I need to add my own?
+ Everywhere I see it seems to be abit much though :(
I really like the Lancool, Dragon Lord I posted up above though :P
I like the case you have, just not got the cash :)
Sounds like you've already decided then, not my cup of tea those lancool things.Look like gamer cases.
Direct noise escape path pretty much negates benefits of any damping materials except vibration resistance.
(which is given by dense mass damping materials, not light foam)
I've order a Fractal Design R2. It has very good cable management, and also ordered 2 more fans for the case + they are exactly the same fans as come with the case, so it all matches :)
