Quiet case for £65?
12 Dec 2005
I'm looking for a case that has fans but isn't loud so I want it to dampen as much noise as possible. Currently have an antec one gaming case but with the fans it is very loud.
Would this be possible with a budget of £65? It will be running an i5 4670k with custom cooler, 280x, 8GB ddr3, 550W PSU, SSD and a HDD.
It works very well on mine - bear in mind however that I went from a pretty basic case with no "acoustic" properties at all!
I have to say though, I can barely hear the fans inside while it's running - the loudest noise is my CD/DVD drive spinning up when I boot the machine up but I think my drive is particularly pants on that front!
Great case imo - loads of room for cable management and looks the business too!
Also available in Black if White is not your thing.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-236-CM
it has a fantastic front panel...... THE BEST, it has a strong spring that closes the font door tight...it's very well engineered.
the case is quite small, but can be modified really easily, mine had twin 120mm roof fans, it made a huge difference to its cooling...it's a gorgeous little case and totally overlooked by everyone...........i got the Phanteks after this
