bitslice said:you could do worse than check out Yewens comments, and see what you think.
Lian Li S80b case review:
http://forums.overclockers.co.uk/showthread.php?t=17596975
http://www.yewen.co.uk/
As was said, you first need to look at every noise producing component you have. A quiet case will only ever be a sticking plaster.
Cheers for that lol saved me the trouble and the cash.Yewen said:Oh and don't bother with sound dampening material. Do a search, you will see nobody likes it and its a pain to remove. All it will do is turn your case into a oven, meaning you need faster fans, and then the padding does not dampen anything, making the PC louder.![]()
Yewen said:Not a review
Yewen said:I have found that I hate the noise the stock fans make
Yewen said:Oh it does work for some people, on some rigs, sometimes.
But for most people it does not work at all.
If its a steel case it may work better, I do not know, all I know is I wont touch the stuff with a bargepole from my ATCs and single PC60 experience of 5deg temperature drops after its removal.
Yewen said:Sound dampening is a waste of time really
Not really. The paxmate that I'm using hasn't affected temperatures at all. There's no reason it should - the chassis provides virtually no heat dissipation, sticking something to it isn't going to change that unless it blocks airflow.Yewen said:Depends how you cool your cases aswell, I for one do not worry about high 40deg case temps if the PC is silent.
I'd rather not have lumps of blutack stuck around my case to stop the panels vibrating. The padding adds mass to the aluminium panels and stops them resonating, it also ensures a tighter fit, making up for the shortcomings in PC7 build qualityThe padding just does not do enough to warrant its application, you can acheive the same results with bluetac for the resonation, and the whoosh sound is the only thing I have ever noticed for the padding.
The room within a room aproach as you say is better, but it is by no means perfect as my PC is making noise at the moment (stock fans at 12v) so it is by no means the ultimate solution.
S80 to me does very little for noise, muffles the hard drive and fan noise.
The only thing I would say it beats any other case I have used at is CDrom noise. A huge reduction in that, but I never minded that noise as it had a purpose and was occasional.
Sound dampening is a waste of time really, if used on it own. It has to compliment a quiet system in it, then it can get rid of that last db and put it out of your hearing range, but for silencing a delta, not a chance in hell!
mosfet said:It would take a lot to silence a delta fan, as far as I'm concerned the only people that use them are benchers/testers and people who don't understand effective cooling.
