Looking at building an 8700k system into this (no graphics card, use is processing not gaming) and I'm trying to figure out what CPU coolers can be fitted in, low noise is high priority since PC sits on desktop.
I know the data sheet says 60mm clearance but it's not clear if this is height from motherboard or top of CPU -- does anyone have an exact measurement for this?
Maybe a Big Shuriken 2 will fit (57mm), or maybe not -- either way clearance to PSU will be very small. Has anyone tried this? [PSU will be Corsair SF450 assuming I can find one, out of stock everywhere]
Maybe a Cryorig C7 (47mm) will keep it cool, but could be too noisy. Cu version is expensive and hardly any cooler according to reports.
Noctua LH9i is quiet and fits but probably won't keep up with an 8700k, even without overclocking. Would an 25mm A9-PWM improve the cooling over the fitted 14mm A9x14, flow is >50% higher?
Looks like an AIO will fit at the bottom of the case, Alphacool Eisbaer LT120 could be an excellent (but expensive) solution -- except their manual says the radiator must be above the pump to avoid noise in case of air bubbles. [anyone know if this is really a problem or them playing safe?]
Any other suggestions?
