Quiet decent fans
27 Mar 2016
Bristolian living in Swindon
Hi all
Looking for 2 or 3 fans to add to my build but not sure what decent fans are about... They don't need to be RGB or colourful just quiet mainly
Cheers
You haven't mentioned size you need so obviously bend this to the size you prefer.
These seem to be a bit of a "hit" at the moment. Really good performance for relatively little money.
https://www.overclockers.co.uk/arctic-cooling-p12-pwm-pst-black-fan-120mm-fg-04h-ar.html
Otherwise usual suspects, BeQuiet and Noctua if you fancy spending a bit more.
Sorry I should've mentioned the sizes... I'm looking for 120mm so the ones you've linked seem great for the job.... I was looking at BeQuiet ones but wasn't sure on performance... Cheers
The ones I linked have a PWM connection and a "piggy back" connector as part of the wiring so you can run multiple from one header (wouldn't advise more than 3) i you needed to.
Ahhh perfect cheers for that... I'm looking to get a AIO Rad at the front for intake so a couple of fans on there will be enough and the exhaust
