In my other thread I mentioned I was having temperature problems with a Noctua 80mm fan on it's quietest setting, I removed the voltage adapters and ran it at full speed and this cured the problem but the trouble is it's quite loud at full speed and my main uses are films and net browsing so it can soon get annoying.
The PC isn't for gaming specifically but I do occasionally play a few so it's a bit inconvenient removing the case lid and swapping the adapters all the time. At full whack the Noctua puts out 31CFM, so if this is the magic figure to keep things cool under all usage is it just a case of finding a bigger (and by default quieter), say 120/140mm fan that puts out the same amount of airflow?
It would be a struggle to fit such a large fan in a SFF case but I reckon I could manage it, worst case I could remove the barely used DVD drive and use that space, it would mean finding a blanking plate for the front though.
Any ideas?
Any ideas?
