Quiet Gaming System advice please!!!
  • Thread starter Thread starter IntoTheVoid
  • Start date Start date
IntoTheVoid
IntoTheVoid
Hi,
I want to build a powerful gaming system that is quiet as well, will the following spec fit the bill?
CA-005-AK Akasa Eclipse-62 Aluminum Case (CA-005-AK)
£66.95 £66.95
CA-001-SS Seasonic S12 500W Silent ATX2.0 Power Supply (CA-001-SS)
£71.95 £71.95
CP-127-AM AMD Athlon 64 X2 Dual Core 4400+ (Socket 939) - Retail (ADA4400CDBOX) (CP-127-AM)
£277.95 £277.95
MB-129-AS Asus A8R-MVP Crossfire (Socket 939) PCI-Express Motherboard (MB-129-AS)
£63.95 £63.95
MY-046-GL GeIL 2GB (2x1GB) PC3200 Value Dual Channel Kit CAS3 (GE2GB3200BDC) (MY-046-GL)
£89.95 £89.95
GX-060-PC PowerColor ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (GX-060-PC)
£239.95 £239.95
HD-018-SA Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM (HD-018-SA)
£53.95 £53.95
HD-002-MI Mitsumi FA 404M 7in1 USB 2.0 Floppy & Media Drive - Black (HD-002-MI)
£12.95 £12.95
CD-026-NE NEC ND4551 16x16 DVD±RW Dual Layer LabelFlash ReWriter (Black) - OEM (CD-026-NE)
£25.95 £25.95
FG-024-AK Akasa AK-183-L2B Ultra Quiet 120mm Fan - 3 pin (FG-024-AK)
£8.95 £17.90
SY-008-ZA Zalman VF900-CU Quiet Copper VGA Cooler (SY-008-ZA)
£25.95 £25.95
SY-007-ZA Zalman ZM-NB47J Northbridge Cooler (SY-007-ZA)
£3.95 £3.95
KB-073-LG Logitech Cordless Desktop S 510 - Black/Silver (KB-073-LG)
£34.95 £34.95
MO-009-NE NEC MultiSync® LCD20WGX2 20.1" Widescreen LCD Monitor - Black/Silver (MO-009-NE)
£359.95 £359.95
Subtotal £1,346.25
Shipping (City Link Parcel Next Day (Delivered Mon-Fri)) £24.95
VAT £239.96
Total £1,611.16
Thanks.
Excellent spec, you will want a diferent cooler for the CPU though (I can't see one listeD) as the stock isnt very quiet.
If you don't want tos pend much then get the arctic freezer 64 and run at 7v, if you have a bit more left in your budget then the scythe ninja.
Edit: The stock X2 cooler is good (XP-90 good) , but it is far from quiet. It uses a 70mm delta fan that goes up to 5000rpm
One of the greatest spec's Ive seen for a while.
The stock 4400 cooler is good, I heard its quite silent. But a 9500 wont hurt :)
