Quiet Keyboard
14 Jan 2009
Manchester
Hello, I am seeking a new keyboard as the one i currently have is a couple of years old. Also it is very loud due to its hard and big keys. I would like this new keyboard to feature, soft (rubber) keys, that aren't too thick, preferably rather thin in size, slightly illuminated keys would be nice (preferably blue, to fit my PC's color scheme). I would also like it to be wireless, but i am not too fussed if it isnt. I have been searching around and i rather like the OCZ Alchemy Elixir, however it doesnt specify, if it has rubber feet, and how loud it is.
I am on a rather tight budget of £30, any help is greatly appreciated
I know OCUK don't appear to stock them, but have you tried the current generation Mac keyboards?
http://images.apple.com/euro/keyboard/scripts/gallery/wired_1_20070813.jpg
Can be bought for under £30, and yes, they do work in Windows, you just need to change the keyboard layout in the control panel.
Other suggestion would be this Hiper unit, the HCK 1G12A:
Which OCUK no longer sell, but ti's quiet good.
Otehrwise, anything from logitech is generally a safe bet, but I don't know enough about their keyboards to recommend much - I have used the above two boards though, and they are both pretty nice.
