Quiet PSU Recommendations
Sem
Sem
18 Oct 2002
London
Hello
i am looking to buy a new quiet psu in the 600-700w range
already tried the seasonic m12 600 last year but under load the thing was very noisy
currently looking at the
Corsair HX 620W
Zalman ZM600
or should i be looking at other models
thanks
Corsair 520W here and its very quiet. Every one here says the 620W is silent too.
is it still silent under load
the seasonic m12 is the same as the corsair except it has a 60mm fan and under load its sooo loud
Ah couldn't tell you to be honest. I doubt my 520w is barely reaching the max with spec in sig and I dont listen to it when I am playing games, however I do like my PC quiet and if it was noisy I am sure I would soon know.
What did you have putting hte seasonic under load? Ive got the M12 600w and i cant hear it.
The corsair is also very quiet. Perhaps you had a duff fan or somethig?
