Quiet/Silent Build Check
19 Jan 2011
Before going ahead on I thought I'd ask for opinions. Currently use will be non-gaming - work docs, music on itunes, streaming video and some photo editing. I will try to run it fanless to see how it gets on, I have a similar cpu heatsink that I could try first to see if this is workable. I can always use fans later if they are needed.
Looking for a modular PSU, doesn't have to be fully, but would prefer only the 2 motherboards cables to be non-modular to reduce cable clutter affecting cooling. I keep reading don't buy a cheap PSU, but the fanless ones certainly are not. There is a fully fanless that fits, the Seasonic X-460 which is a similar price to the Seasonic X-650 (which should run without the fan as it is low-power system). The pico is low power and not that cheap once a power brick is added and in the longer term would restrict upgrades.
Asus mATX H77 or Z77 motherboard preferred as I have another system with a P8Z77.
I3-3225 for low power usage.
System, programs should fit on the SSD, I may fit an HDD, but still to decide.
An External optical disk as only needed for the odd software load or music cd.
I'll probably get a new keyboard as I only have working PS2 ones at the moment.
YOUR BASKET
1 x Silverstone Fortress FT03 Tower Case - Titanium (SST-FT03T USB 3.0) £117.98
1 x Seasonic X-Series 650w '80 Plus Gold' Modular Power Supply £114.98
1 x Asus P8H77M-LE Intel H77 (Socket 1155) DDR3 MicroATX Motherboard £79.99
1 x Intel Core i3-3225 3.30GHz (Ivybridge) Socket LGA1155 Processor (55W) - Retail **High Performance IGP** £102.98
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £49.99
1 x Arctic Cooling Freezer Xtreme Rev.2 High Performance Quiet CPU Cooler(Socket 775 / 1155 / 1156 / 1366 / AM2 / AM2+ / AM3 / FM1 / FM2) £29.99
1 x Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) £119.99
1 x Samsung SE-S208DB/TSBS External Slimline 8x DVD-RW (TV Connect) - Black £21.98
Total : £652.90 (includes shipping : £12.50).
The case, PSU and heatsink would seem to be the main areas where I am unsure, but I want to build around something with plenty of airflow, small footprint and restrained styling.
The last pc I built down to a price and have regretted it ever since, I don’t want to make the same mistake again.
Re the X-650 I can't fault and will be silent on the wattage your pulling. I own 3 Seasonic X series myself and won't choose anything else now.
On the cooler I run the Artic i30 below on i7 Ivy, these coolers are quieter then most. They only spin up-to around 1200rpm but for the i3 it won't ever run at this speed due to wattage. The i30 maybe a better choice if your keeping the noise levels down.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-041-AR&groupid=701&catid=2330&subcat=2338
I use Silverstone cases and they are good quality but know nothing about the case you have chosen.
