Lian Li PC-7+:
- Dimension: 210x450x490 mm ( W,H,D)
- Drive bays 4x5.25", 2x3.5", 3x3.5" internal
- Fan: 12 cm ball bearing x 1, 8 cm sleeve fan x 1
- M/B type: ATX & pentium 4 (max size: 12"x9.6")
- PSU Type:ATX
- USB2.0 x 2 IEEE 1394 x 1MIC x 1EAR x 1
Or if you want something smaller:
Lian Li PC-A05B Aluminium Midi-Tower - Black
- 5.25”bay x 2, 3.5”x 1, 3.5”internal x 3
- Fans 12cm ball bearing fan x 2
- M/B Type ATX M/B(max size: 12”x9.6”)
- Top I/O USB 2.0 x 2, IEEE1394 x 1, MIC x 1, EAR x 1
- Dimension 210x381x490mm (W,H,D) 8.26'' x 15'' x 19.3''
- Slot PCI slot x 7
Or if you're going Micro-ATX:
Lian-Li PC-V300 Aluminum Micro ATX Mini Tower Case - Black
- 5.25"x 2, 3.25"x1(position can be exchanged on right or left), internal HDD x 2
- 8 cm Ball bearing fan x 3( 2 rear holes for option 4cm fan)
- Micro ATX (max size: 9.6"x 9.6")
- USB2.0*2, IEEE1394*1, MIC*1, EAR*1
- 280*250*353 mm(W,H,D)
- Takes ATX PSU
