Quiet Socket 423 cooler
9 Nov 2004
Northern Ireland
Just spent a couple of hours putting together a few old computer bits and have come up with a cheap NAS box. Going to stick this up in the loft and run some network cable up there. Only problem is that it's so loud!! :(
It's running an old socket 423 2GHz P4 and the stock heatsink sounds like a jet fighter taking off. If i put this thing up in the loft I'll be able to hear it through the ceiling. Could anyone recommend a cheap and quiet skt423 cooler??
Can only think of one place you will find socket 423 coolers (And I can't say)
Theres a coolermaster on on there dont look bad or you could fit your own fan to the current one
