- 25 Mar 2004
- Fareham
I am looking for a case to replace my Lian Li PC7 that is rather noisy!
it should meet the following criteria where possible:
I quite like the look of the Antec P182 and from the reviews it seems good, are there others I should consider for the task?
- Have good ventilation with either quiet stock fans or the ability to put my own quiet ones in
- The case should have a fair bit of room inside as space is not an issue, well designed etc is a good bonus
- Not too overstated, no need for flashy lights or windows, a sleek understated look would be good
- No need for PSU to be included I have one already
) it's more the case vibrates like crazy + I don't really like it that much anyway
