Quieter alternative to K70 RGB
9 Jun 2006
I have a Corsair K70 RGB with Cherry Red switches, but unfortunately it is too noisy for those around me, despite having fitted O-rings. I think now it is the spring back of the keys that are producing the most noise now, which I don't think I can do anything about.
I like having RGB LEDs, simple design, and high quality build of the K70. Just need something quieter! Thinking of the Corsair Strafe might be a good choice?
Appreciate any advice/recommendations.
Thanks
I've got the strafe rgb silent mx and it's definitely quieter than mx browns. You could also add o rings but I haven't needed to. Build quality isn't as good as a K70 but it's quite a handsome board that's grown on me. Backlights are better than the K70 too thanks to the white backplate. Hope this helps.
Best
Wulf ;)
Can't you just swap out the whole keyboard for the same one with different switches? From the looks of it you can get it with browns, which would likely be much more quiet. That or you could get rid of the people around you, whichever is easier!
I've currently got a K70 with brown switches, also tried one with red and they're probably about the same noise wise.
As mentioned the strafe with silent switches would be good option, have used one of those as well but didn't like the build quality compared to the K70
