- 11 Aug 2005
- UK
I have a Lian-Li PC-60 Plus case and i'm looking to replace the fans in my system as its too noisy.
The fans I have are:
- 1 80mm rear case fan;
- 1 80mm top case fan;
- 1 120mm front (HDD) case fan;
- 1 fan on Leadtek 7800GT Graphics card;
- 1 CPU cooler fan - Zalman CNPS9500-LED;
- 1 fan on DFI LanParty UT NF4 SLI-D motherboard;
- 1 Hiper HPU-4K580-MK Type R 580W PSU.
It is my first build and i'd like to replace the case fans to help reduce the noise. Can anyone suggest which fans are the quietest to use - LED fans would be a bonus but i want it to be as quiet as possible.
Or is there anyother alternatives?
Thanks
Thanks
