Hi all,
Wondering if anyone can help currently running a Q6600 at stock don't overclock at the moment, i got rid of the OEM fan and replaced it with a FREEZER PRO 7 however it appears noiser than the stock cooler the cpu came with, i found myself using SPEEDFAN to turn it down to 80-90 % however is there anyother coolers out there that are near enough silent that i could use as i don't Overclock. Looking at max spend of £35-40.
Thanks in advance
Thanks in advance
. . . you may need a fan . . . but if your case is well ventilated you may be fine *Passive*
